Why Do I Get Error Code 30005 in First Descendants Every Time I Close the Game?
402 viewsComputer
So, you keep running into this pesky error code 30005 when you try closing The First Descendant, huh? Don’t sweat it. It’s usually linked to Easy Anti-Cheat (EAC) acting up. Here’s a rundown on what might be going wrong and how you can sort it out.
What’s Up with Error Code 30005?
  • Messy Game Files: Sometimes, essential files for the game or EAC decide to go missing or get corrupted. Annoying, right?
  • Security Software Hiccups: Antivirus programs occasionally get a little overzealous and might mistake EAC for something sinister, causing a ruckus.
  • Outdated Graphics Drivers: Keeping stuff up-to-date is key. Old graphics drivers can just mess with game compatibility.
  • EAC Installation Mishaps: Glitches during EAC setup can also throw this error in your face.
Let’s Get This Fixed Up
Check Your Game Files
  • Pop open Steam, head to your Library.
  • Spot The First Descendant, right-click, and dive into “Properties.”
  • Hit up “Local Files” and then “Verify Integrity of Game Files.”
Ease Up on the Anti-Cheat
  • Dig into Windows Security. You can find it via the Start menu.
  • Go to “Virus & threat protection”, then “Manage settings.”
  • Stroll down to “Exclusions” and add the EAC folder from The First Descendant directory to keep your security software from butting in.
Update Those Graphics Drivers
  • If you’re team NVIDIA, right-click your desktop and choose “NVIDIA Control Panel,” then snag any updates under the Help menu.
  • For AMD gang, fire up AMD Software Adrenalin and fetch updates from the Home section.
Reinstall Easy Anti-Cheat
  • If things are still wonky, you might have to reinstall EAC:
  • Head to The First Descendant folder via Steam (manage then browse local files).
  • Hunt down EasyAntiCheat_EOS_Setup.exe and follow the steps to fix or reinstall it.
Try Running Easy Anti-Cheat Manually
  • Sometimes, just kicking things off manually can help:
  • Find EACLaunch.exe in the same directory and fire it up before launching the game through Steam.
In the end, these steps should help you kick that error to the curb. Just make sure everything related to the game and EAC is in sync. Best of luck getting back to your game without a hitch!
Hey there! If you keep running into that pesky Error Code 30005 every time you shut down The First Descendants, you’re not alone. It’s like when your car’s engine light keeps popping on, and you’re not sure what’s causing it. This error usually means there’s some hiccup between your system and the game’s shutdown process. Here’s what we’ve got:
Getting to Know Error 30005:
This error mainly happens because of a service conflict or because your system isn’t playing nice with the game’s shutdown. The “StartService failed with 1450” bit often hints at resource issues or permission hang-ups that stop the game from closing smoothly.
What Might Be Going Wrong & Fixes:
  • System Service Mess-Ups:
    • Basically, the game counts on certain Windows services (think .NET Framework and anti-cheat stuff) to wrap things up, and they’re not doing it correctly.
    • Fix it:
      • Run a System File Check to patch things up: Go to Command Prompt (admin mode) and type sfc /scannow. Let it do its magic.
      • Hit up Steam: Right-click your game > Properties > Installed Files > Verify.
      • Make sure Windows is updated with the latest and greatest patches.
  • Permission Roadblocks:
    • Sometimes, antivirus or those annoying prompts stop the game from wrapping up.
    • What to do:
      • Let the game run as admin: Right-click its .exe file > check Run as Administrator.
      • Turn off security software temporarily and see if that changes anything.
  • Driver Drama:
    • Outdated drivers (think graphics cards or audio) can mess things up.
    • Solution:
      • Keep GPU drivers current with NVIDIA’s or AMD’s software.
      • If you’re using an Xbox controller, reconnect to make sure drivers are fresh.
  • Runtime Library Issues:
    • Visual C++ and .NET Framework might be the culprits if they’re corrupted.
    • How to fix:
      • Download and install their newest versions from the Microsoft website.
  • Too Much Going On:
    • If your system’s overloaded, it might struggle with shutting down the game cleanly.
    • Easy fixes:
      • Clear out unessential apps via Task Manager (Ctrl+Shift+Esc).
      • Adjust virtual memory settings: Task Manager > Advanced > Virtual Memory. Let it go system-managed.
And if you’re a bit more tech-savvy:
  • Dig into Event Viewer to see what’s really going wrong.
  • Try a clean boot to root out the problematic processes.
After all’s said and done, make sure everything’s up-to-date and avoid overclocking your hardware when playing. Still stuck? The game’s support team might be your next stop, complete with logs and details of what you’ve tried so far.
Hope this helps and happy gaming!
Hey, I’ve encountered that annoying Error Code 30005 myself while playing ‘First Descendants.’ Here’s how I managed to tackle it:
  • Check Your Game Files: Go ahead and fire up your game launcher like Steam. Head over to your library, find ‘First Descendants,’ and right-click on it. Hit ‘Properties,’ find the ‘Local Files’ tab, and then click ‘Verify Integrity of Game Files.’ Fingers crossed!
  • Reinstall Easy Anti-Cheat: Dive into the ‘First Descendants’ installation folder, find the ‘EasyAntiCheat’ folder, and run that ‘EasyAntiCheat_Setup.exe’ file. Just choose ‘Install’ or ‘Repair’ and follow those on-screen prompts. Should be a breeze.
  • Cut Out Conflicting Software: Double-check that nothing’s messing with Easy Anti-Cheat, like your antivirus software or those pesky disk optimizers. You might want to add ‘First Descendants’ and Easy Anti-Cheat to the exceptions list in your antivirus settings.
  • Update Your Drivers: If your drivers are outdated, it can cause all sorts of chaos. Visit your graphics card manufacturer’s site and download the latest drivers to keep everything running smoothly.
  • Keep Windows Fresh: Make sure your operating system is up to speed. Hop over to ‘Settings,’ then ‘Update & Security,’ and finally ‘Windows Update’ to install any updates.
  • Tweak Your System Settings: Are you overclocking? Might be a good idea to set everything back to default. Also, check if the game needs admin permissions. Just right-click the game shortcut, pick ‘Properties,’ hit the ‘Compatibility’ tab, and tick ‘Run this program as an administrator.’
These steps should hopefully do the trick! But if you’re still stuck with that error, it might be worth reaching out to the game’s support team or chatting with fellow players on forums. Good luck!
