Can I Use My Ring Doorbell with Google Home?
451 viewssmart home devices
When it comes to smart gadgets, getting them to play nice together is key for a smooth experience. If you’ve already decked out your space with Google devices, you might be wondering how the Ring doorbell fits into the mix. So, does it work with Google Home?
Well, kind of. Ring can buddy up with Google Home through Google Assistant, but don’t expect the same magic you’d get with Amazon’s Alexa. You’ve got some features to play with, but a bunch are just off-limits if you’re living in the Google ecosystem.
Let’s break it down so you know what you’re in for when connecting Ring and Google Home:
What You Can Do
  1. Check Battery Levels: No more guessing! You can easily keep tabs on the battery levels of your Ring cameras using the Google Home app.
  2. Receive Motion Notifications: Get a heads-up when your Ring doorbell spots movement.
  3. Control Recordings: Fancy starting or stopping recordings with just a voice command or a tap? Google Home lets you do just that.
What You Cannot Do
  1. Live Video Feeds: Sorry folks, no peeking at live video feeds from your Ring through Google Home like you can with Alexa or the Ring app.
  2. Two-Way Talk: Chatting back and forth via the doorbell? Not happening with Google Assistant.
  3. Direct Control of Security Settings: If you’re hoping to tweak your Ring security settings using Google Home, you’re out of luck here.
It’s not surprising – Ring is under Amazon’s umbrella, so naturally, the company puts more effort into making their products gel with their own devices than with a rival like Google.
If you’re still eager to connect Ring with Google Home, here’s a quick rundown:
  1. Open the Google Home App: Get that app open on your phone or tablet.
  2. Access Assistant Services: Dive into the Assistant Services part of the app.
  3. Sign In: Log into your Google account and Ring account.
  4. Link Devices: Follow the steps to link your Ring device, which might include giving permissions for access between accounts.
After linking, you’ll have access to some of those basic functions we talked about.
If you’re yearning for a smoother integration, there are other paths to tread:
  • IFTTT (If This Then That): This service lets you craft custom automations to bridge gaps between devices. Maybe set it up so your lights switch on when Ring senses motion!
  • Home Assistant: If tech tinkering is your jam, this open-source platform might be your ticket to deeper integration with Ring and Google gadgets.
To wrap it up, yes, your Ring doorbell can work with Google Home, but know the limits when it comes to functionality compared with Amazon’s ecosystem. Notifications and battery checks? Check. Live video streaming and two-way chatter? Not so much here.
If you’re gunning for a thoroughly unified smart home setup with Google’s devices, looking at Nest products could give you that close-knit compatibility you’re after.
Ring Doorbell and Google Home: Compatibility Showdown
Trying to get your smart gadgets to play nice? Buckle up, because getting Ring Doorbell to work with Google Home is a bit of a bumpy ride.
1. Where They Stand Together
Ring Doorbell is really made for Amazon’s Alexa, not Google Home. You won’t get a seamless mesh here, but there are some nifty tricks to make them sort-of work together.
  • In a Perfect World:
    • Google Home doesn’t chat directly with Ring Doorbell. You’ll miss out on video feeds, motion alerts, and that handy chit-chat feature. Alexa nails this part, especially with nifty gadgets like Echo Show.
  • Google Home Gets a Makeover:
    • You can loop in some third-party hubs like Samsung SmartThings to serve as matchmaker.
    • Plug IFTTT into the mix so your lights can freak out when the Doorbell spots a lurker.
2. Glitches & How to Fix Them
No Video Love on Google Nest Hub
  • What’s Happening?:
    • Ring keeps its video streaming locked to its pals at Amazon.
  • What’s the Fix?:
    • Move your loyalty to Alexa-enabled gizmos like Echo Show for all the bells and whistles.
    • Dare to cast Ring footage to your TV using Chromecast, but you’ll have to manually swipe away on the Ring app.
Notifications Playing Hide and Seek
  • The Culprit?:
    • Google’s got no backstage pass for Ring’s instant alerts.
  • The Remedy?:
    • Employ IFTTT to whisper Ring alerts in Google Home’s ear through voice announcements.
    • Example setup: “When Ring detects motion, let Google Assistant chirp, ‘Hey, someone’s at the front door.’”
Voice Commands MIA
  • What’s Up?:
    • Google Assistant doesn’t speak Ring’s language for unique commands.
  • How to Tackle It:
    • Craft Alexa routines and patch them to Google Home with voice triggers.
    • Example script: “Okay Google, ask Alexa to show the front door camera.”
Packing Up Your Smart Home
If you want everything to just work without fuss, consider these swaps:
  • Jump Ship to Google Nest Doorbell:
    • It naturally buddies up with Google Home, offering live feeds and smart alerts.
  • Get Crafty with a Universal Hub:
    • Test out Home Assistant or Hubitat to harmonize Ring and Google Home (but be ready for some techy legwork).
The Inside Scoop on Ecosystem Loyalty
Brands like Ring and Google Home often want to keep you hooked by keeping everything in their family. Since Ring belongs to Amazon, and Google Home operates in its own realm, expect some tug-of-war when it comes to compatibility.
Wrapping It Up: What’s the Move?
  • For basic alerts: Lean on IFTTT or team up Alexa with Google Home.
  • For total control: Go for Google Nest Doorbell or dive deep into Amazon’s Echo lineup.
  • For hands-on folks: Try universal hubs if you’re up for an adventure in DIY smart home setup.
Knowing the push and pull between these systems can really help you rock your smart home setup despite the quirks of their compatibility dance.
Hey there! You bet the Ring Doorbell gets along with Google Home, thanks to Google Assistant. It’s not a direct match made in the Google Home app, but you can work some magic with Google Assistant to make it happen. Let’s dive in:
1. Grab your phone and pop open the Google Home app.
2. Smash that + button to bring a new device into the mix.
3. Hit “Set up device,” then go for “Works with Google.”
4. Punch in “Ring” in the list of services, and pick it out.
5. Log into your Ring account to seal the deal on the connection.
Alright, now you can get chatty with Google Assistant and handle things like:
  • Finding out what’s going down with your Ring Doorbell
  • Kicking off recordings
  • Getting heads up from your device
Heads-up, you can control some bits, but streaming Ring Doorbell video on Google Nest Hub displays isn’t in the cards yet. For some fancy automation, check out third-party options like IFTTT.
This setup is perfect for dialing up your smart home game with voice control, making life just that bit easier every day.
If you’re itching for more info, take a peek at the official support pages at Ring and Google Assistant.
