Does Google Home Work with Samsung Tv?
373 viewsTelevisions
So, you’re curious if Google Home can work with your Samsung TV? Let’s dive in and figure this out together.
First off, there’s the matter of compatibility.
If you’ve got a newer Samsung TV, like the 2022 or 2021 models, you’re in luck. These come with Google Assistant built right in, meaning you can simply start talking without any extra gadgets. Sweet, right? But heads-up: If you’ve got a Samsung TV from 2023 or later, it’s not going to support Google Assistant anymore.
Now, if your TV’s a bit older or doesn’t have that built-in feature, don’t worry. As long as it supports the SmartThings app, you’re good to go. The app becomes the middleman between your TV and Google Home, letting you control the TV with your voice through Google Home.
Alright, let’s get you connected.
For those newer TVs with Google Assistant already onboard, it’s super simple:
  • Make sure your TV and Google Home are on the same Wi-Fi.
  • Fire up the Google Home app, log in, and hit that “+” icon to add a new device.
  • Select “Set up device” and then “Works with Google.”
  • Pick your Samsung TV from the list and follow the prompts. Bam! You can now say things like “Hey Google, turn on the TV” or “Hey Google, play a movie on the TV.”
Now, for the SmartThings setup:
  • Download the SmartThings and Google Home apps on your phone, and connect everything to the same Wi-Fi.
  • Add your TV to SmartThings through the app. Go to “Device” > “Home,” pick where you want to add the TV, then follow the steps to get it linked.
  • In the Google Home app, go to “Devices” tab, tap on “+ Add,” then select “Works with Google Home.” Find “SmartThings,” log in, and complete the linking process. Woo-hoo, your TV is now ready to follow your voice commands!
Now, onto the fun part—using your voice to boss your TV around. You can say things like:
  • “Hey Google, turn off the TV.”
  • “Hey Google, mute the TV.”
  • “Hey Google, play Stranger Things on Netflix.”
If your TV has the Assistant built in, you can also ask about the weather, search for YouTube content, and even control other smart home devices.
On the smart home side, integrating your Samsung TV with Google Home means you can bundle it into routines. Imagine saying “Hey Google, movie time,” and your TV turns on while the lights dim. Or “cozy evening” lowers the TV volume and adjusts the thermostat. Pretty neat, huh?
If you hit a snag while setting things up? No sweat. Just make sure everything’s on the same Wi-Fi, apps and firmware are up to date, and your TV is compatible. And if your TV’s been chatting with Alexa, you’ll find Google Assistant in the settings menu to switch things up.
Hope this helps you get your Samsung TV chatting with Google Home like a pro!
So, you’re wondering if Google Home can cozy up with your Samsung TV? Let’s dive into that. It’s not as straightforward as one might think, but here’s the deal.
Google Home does play nice with Samsung TVs, but don’t expect it to work with every model under the sun. You’re looking at TVs from 2018 and onwards; those fresh-off-the-production-line models will generally sync up pretty well, thanks to the SmartThings app. And don’t forget, some newer models from 2020 onwards even come packed with Google Assistant right out of the box! But—and here’s the bummer—Google is pulling the plug on Assistant for Samsung TVs starting March 1st, 2024. Talk about a major curveball!
Moving on, let’s talk setup! This isn’t rocket science:
  • Firstly, make sure your Samsung TV is of the right vintage (2018 or later) and is rocking the latest firmware.
  • Next, grab the SmartThings app and Google Home app on your smartphone—you’ll need these two apps to seal the deal.
  • Lastly, get your gadgets chatting:
    • Your phone and TV need to be on speaking terms via the same Wi-Fi.
    • Fire up that SmartThings app and claim your TV as a new device. Tap around till you see the option to add your TV and follow the on-screen niceties.
    • Once that’s done, slide into the Google Home app and link it up with SmartThings. A couple of taps and some logging in to your SmartThings account will do the trick.
Voice commands? Oh, they’re a breeze once you’re all set up. You’ll be telling your TV to turn on, play your favorite shows, or even skip channels like you’re some kind of modern-age wizard. Who needs a wand when you’ve got your voice, right?
Alright, here’s what you really want to know: Google Home works with certain Samsung TVs, letting you bark commands and feel like a tech-savvy genius. Just keep your eyes peeled for Google’s policy change in 2024—it might shake things up.
And that’s your lowdown on getting your tech to talk to each other like they’re old pals.
Can Google Home Team Up with Samsung TV? Here’s the Scoop!
If you’re juggling between Google Home and your Samsung TV, there’s good news—there’s a way for these two to be best buddies! But hang tight, because how they play together depends on some things like the TV model, software version, and the magic of your network. Let’s dive into it.
Getting the Lowdown on Compatibility
  • Plug and Play: If you’ve got a Samsung TV from 2018 or later, chances are you’re in luck. These newer models running Tizen OS 4.0 or above can really hit it off with Google Home. You’ll be able to throw voice commands its way, like telling it to turn on your TV.
  • The Catch: Got an older Samsung TV? Well, you might have to pull a few tricks to get them talking by using something like Chromecast or syncing with SmartThings.
Setting It Up: A Couple of Tricks
Method 1: The Google Home Express
If you’ve got the latest tech:
  • Your Samsung TV must be from 2018 onwards and rocking Tizen OS 4.0 or more.
  • Have the Google Home app handy on your phone.
  • Make sure all your gadgets are cozy on the same Wi-Fi.
Then, follow these steps:
  1. Pop open the Google Home app, tap on that juicy +, then head to Set up device followed by Works with Google.
  2. Simply look up “Samsung TV” and get your Samsung account hooked up.
  3. Assign the TV to a room and give it a whirl with a voice command like, “Hey Google, pause the TV.”
Plan B: Chromecast or SmartThings Route
If your TV is giving you the cold shoulder:
  • Chromecast Ultra: Pop it into the HDMI port, let it mingle with your Wi-Fi, and cast content using Google Home.
  • SmartThings Hub: Sync the TV up with SmartThings, and link that to Google Home for basic commands—power on/off, switching inputs, you name it.
Troubleshooting: No Sweat
Problem 1: “Device Not Found!”
  • Possible Reasons: Network gremlins, firmware being crappy, or not linking accounts right.
  • Solutions:
    • Make sure the TV and Google Home are on the same page network-wise (time to ditch those guest networks).
    • Give your Samsung TV a firmware boost using Settings > Support > Software Update.
    • Re-link that Samsung account in the Google Home app, and you’re gold.
Problem 2: Limited Voice Command Vibes
  • Possible Reasons: Restrictions from Samsung’s API or maybe some regional quirks.
  • Solutions:
    • Drop some specifics like “Play [show name] on Netflix” rather than vague stuff like “Turn on TV.”
    • Sneak in apps like SmartThings to stretch those control abilities.
Problem 3: Casting Mess-ups
  • Reasons: Unsupported apps or the Wi-Fi being a diva.
  • Solutions:
    • Stick to apps that play nicely with Cast support (YouTube, Netflix—those guys have your back). For other apps, try screen mirroring via Google Home > Cast Screen.
    • Get that Wi-Fi humming smoothly by flipping to 5GHz bands or shuffle the router around for a better signal.
Mixing It Up: Other Options
  • AirPlay 2: If you’re Team iPhone, zap content to Samsung TVs (2020 and later) with AirPlay.
  • Third-Party IR Blasters: Gadgets like Broadlink RM4 Pro can be your ace in the hole, letting Google Home control older TVs using infrared magic.
Why All the Fuss?
Samsung uses its own special Tizen OS for its TVs. It’s super friendly with SmartThings, but when it comes to Google Assistant, it’s gonna need some extra help, like middleware integration. Newer TVs love support from different platforms, while older ones might need a little help from add-ons.
By sticking to these pointers and giving the troubleshooting a whirl, you should have Google Home and your Samsung TV gabbing away in no time. For those sweet extra features, you might consider sidestepping into a newer TV model or adding some cool tools like Chromecast to your kit.
You betcha, Google Home can totally work with Samsung TVs, but you gotta make sure your TV is down with Google Assistant or Chromecast. Here’s the scoop on getting them to play nice together.
First things first, make sure your Samsung TV is cool with Google Assistant. Dig out that TV manual or hit up Samsung’s website to figure this out.
Second, you gotta get your Samsung TV and Google Home connected to the same Wi-Fi. They’re like kids, better together than apart.
Alright, now let’s switch over to turning on Google Assistant. On your TV, cruise over to Settings, hit General, then Voice, and pick Voice Assistant. Punch in your Google account details, and you’re golden.
Got the Google Home app on your phone? Swell, open it and hit the “+” to add a device. Choose “Set up device,” then “Works with Google.” Just search for “Samsung SmartThings” and sign in to your Samsung account to link those bad boys.
Once you’ve nailed the setup, you can throw commands like a boss. Just say “Hey Google, turn on the TV” or “Hey Google, increase the volume.” Piece of cake, right?
And if you’re itching for more info, swing by Samsung Official Support or Google Home Help for all the nitty-gritty details.
