How Can I Display External SSD Storage Remaining on my macOS with a Widget?
347 viewsLaptops
1 Answer
Here’s how you can check out what’s happening with your external SSD storage on your Mac using some nifty tools. Let’s jump right in!
Stats Widget:
This one’s a real gem. It’s free, open-source, and hangs out right in your macOS menu bar, doing all the heavy lifting for you.
  • First off, snag Stats from its GitHub page.
  • After you pop it into Applications and fire it up, just tap the Stats icon up there in your menu bar.
  • From there, you can set up the disk widget to keep tabs on your external SSD’s space. Easy-peasy!
iStat Menus:
Talk about a powerhouse! iStat Menus gives you the lowdown on just about every part of your Mac, SSD included.
  • Head over to the official iStat Menus site and get it cooking on your Mac.
  • Inside the app, hit up the “Disks” area.
  • You can tweak it to show off your SSD’s stats right up there in the menu bar. No sweat!
DaisyDisk:
DaisyDisk feels a bit like magic, with its visual storage maps. Makes seeing what’s hogging your SSD space a breeze.
  • Grab DaisyDisk from their site and get it up and running.
  • Give it a whirl, scanning your SSD to check out the detailed breakdown.
  • They’ve also got this neat “QuickLook” thing—you get a peek at your storage info straight from Finder.
And there you go, three cool tools to stay on top of your SSD situation in macOS. Each has its own flavor, so take your pick and see what works best for you!
