Why is Discord downloading update 1 of 1 stuck on my Mac?
368 viewsLaptops
So, you’re trying to update Discord on your Mac, and it’s just hanging on \’Downloading Update 1 of 1\’? Ugh, that’s frustrating! But don’t worry; we’ve all been there. Here’s how you might tackle this little snafu:
First things first, make sure Discord isn’t having a meltdown—no point fixing your computer if it’s their servers acting up. You can glance at the Discord Status page for any red flags. Also, check if your internet’s working smoothly; maybe your Wi-Fi needs a quick reset, or plug in an Ethernet cable if you’re feeling retro and want to rule out any connectivity gremlins.
Next, give your Mac a swift restart—it’s like giving it a good ol’ shake. Sometimes, that’s all it needs to clear out the cobwebs. Oh, and don’t forget to keep macOS up-to-date; those updates can fix compatibility curves that we don’t always see coming.
If nothing’s budging, it might be time to dig into Discord’s closet and do a lil’ spring cleaning. You know the drill: Finder > Go > Go to Folder, type in ~/Library/Application Support/Discord, and zap those Cache, GPUCache, and Code Cache folders. A clean slate could help!
Still stuck? Maybe Discord’s acting like a drama queen and needs the royal treatment—aka, a full uninstall and reinstall. Drag it to the Trash, make sure it’s not secretly lurking in Activity Monitor, and snag the newest version from Discord’s site. Fresh start, fresh hopes!
Running out of luck might mean trying to launch Discord with a bit of extra oomph. Close it through Activity Monitor, then right-click the app in Applications, and hit \”Open\”—this gives it the nudge it might just be missing.
Finally, for the brave hearts who don’t mind getting their hands a bit dirty with tech stuff—tweaking the ShipItState.plist file has helped some folks, but tread carefully. Make those backups first!
At the end of the day, the key is to be patient and try these fixes step by step. We’ve all been there struggling with updates, and with a bit of fiddling, you’ll likely be back to chatting away on Discord in no time. Good luck!
Stuck on Discord\’s \’Downloading Update 1 of 1\’ on your Mac? You\’re definitely not alone. Here’s how to fix it.
Sometimes, when you\’re trying to update Discord on a Mac, it\’ll hit a snag showing the dreaded \’Downloading update 1 of 1.\’ Why does this happen? Well, a hiccup with your network, some finicky permission settings, or even a bit of software trouble might be the culprits.
Let’s break down what might be going on and how you can get things rolling again.
Network Glitches:
First off, let’s talk about your internet connection. Sometimes, Discord’s update servers can be elusive because of a sketchy connection or your ISP playing hard to get. Here’s your game plan:
  • Swap between Wi-Fi and Ethernet and see if things speed up.
  • Use a VPN to sidestep any funky regional blocks.
  • Give firewalls and security software a break to see if they’re the ones throwing a fit.
  • Feeling techy? Flush out your DNS cache with this little Terminal trick:
    sudo dscacheutil -flushcache; sudo killall -HUP mDNSResponder
Permissions Drama:
Macs are pretty tight when it comes to security, and sometimes they lock Discord out of the action. To smooth things out:
  • Head over to System Settings, then Privacy & Security, and double-check that Discord isn’t being ghosted in the Accessibility and Screen Recording sections.
  • Always hit “Allow” on those prompts for mic or keyboard access—super crucial.
  • If all else fails, reinstall the app to clear out any permission cobwebs.
Busted Update Files:
If you’ve tried to update before and it flunked, that could be messing things up now.
  • Make sure Discord is completely closed (right-click its icon in the Dock and quit it).
  • Go erase that pesky “Update” folder in ~/Library/Application Support/discord.
  • Fire up Discord again to prompt a clean update.
Compatibility Clashes:
Could it be that your Mac’s OS is playing hardball with the latest Discord version? Check where you\’re at:
  • Under the Apple menu, click About This Mac. You want to be on macOS 10.15 or higher.
  • If not, it might be time for a trip to System Settings for an OS update.
Still Stuck?
No worries. If automatic updates are still throwing a tantrum, just grab the latest version from Discord’s website:
  1. Trash your old Discord app from the Applications folder.
  2. Install the freshly downloaded version.
  3. Give your Mac a restart to seal the deal.
More Tricks Up Your Sleeve:
If this problem just won’t quit, try these ideas:
  • Fix ruby environment snags or disk space shortages with some terminal and Disk Utility magic. Don’t fret if this sounds techy—these tweaks ensure everything runs like butter.
  • And hey, remember Discord has a web version at discord.com that works without these update woes. It might lack a few app perks but keeps you connected.
Hang in there! These hiccups usually sort themselves out, especially if Discord’s servers are feeling the heat. Give it a little time and see if things sort themselves out before diving into troubleshooting.
Happy Discord\’ing!
Running into an issue where Discord just won’t budge past “downloading update 1 of 1” on your Mac? Don’t worry—you’re not alone, and thankfully, there are a bunch of things you can try to kick it back into gear.
  1. Check Your Internet Connection:
    • First things first, double-check that your internet is working fine. A glitchy connection might be the sneaky culprit here.
  2. Give Discord a Restart:
    • Sometimes, all you need is a little reboot. Quit Discord by right-clicking its dock icon and hitting “Quit.” Fire it up again and see if that does the trick.
  3. Reboot Your Mac:
    • This might sound like a no-brainer, but restarting your Mac can often solve weird app hiccups. Once it’s back on, try launching Discord again.
  4. macOS Updates, Anyone?
    • Check that your macOS is up to date. Apple sometimes sneaks in updates that can fix these kinds of headaches. Just hop into “System Preferences” and click on “Software Update.”
  5. Clear Out Discord’s Cache:
    • Old cache files can mess with app updates. Head over to ~/Library/Application Support/Discord, find that “Cache” folder, and toss it out. Then, see if Discord behaves.
  6. Go for a Fresh Reinstall:
    • If nothing’s working, it might be time for a clean slate. Uninstall Discord by popping it into the Trash, download the latest version from the official site, and reinstall.
  7. Check Discord’s Status:
    • Sometimes it’s not just you—it’s them. There could be server issues mucking things up. Hit up Discord’s status page to see if they’re having any hiccups on their end.
If you’re still hitting a wall, don’t hesitate to reach out to Discord support. They’re usually pretty good about helping folks out of these jams.
