How can you use a Chromebook as a monitor for your devices?
195 viewsLaptops
Want to use your Chromebook as a monitor? It isn’t as straightforward as just plugging it in, but here’s how you can do it with a bit of a workaround.
  • The Wired Way:
    Chromebooks don’t naturally have an HDMI input, but that doesn’t mean you’re out of luck. You can use a USB-to-HDMI capture card. It’s a nifty little gadget that lets you hook devices up to your Chromebook.
    1. Grab a USB-to-HDMI capture device.
    2. Connect your device’s HDMI output to the capture device.
    3. Plug the capture device into your Chromebook via USB.
    4. Fire up some software that’ll let you see the video feed on your Chromebook—there’s a bunch out there to choose from.
  • Trying the Wireless Route:
    Don’t like all those wires? There are apps for that. Apps like Duet Display and Space Desk can work their magic to get your Chromebook acting as a second screen without the physical fuss.
    1. Download a compatible app on your external device and Chromebook.
    2. Make sure both devices are sipping from the same Wi-Fi connection.
    3. Open the app on both devices and follow the setup prompts. It’s usually pretty straightforward.
Remember, both methods need a bit of extra hardware or software, and they’re not as seamless as sticking to proper monitors, but they do the trick in a pinch. Before diving in, check if everything plays nicely with your Chromebook’s specs.
Ever thought about using your Chromebook as a monitor? Well, it\’s a bit tricky because it doesn\’t have the right ports for direct use—no HDMI input, just output. But don\’t worry, there are some clever software solutions to get around this! You can get your Chromebook up and running as a display using network or USB connections.
Here\’s the kicker: You can\’t just hook it up with a cable and expect it to work. Instead, you need some nifty software on your main computer (whether it\’s a PC or Mac) and on your Chromebook. Some popular options are Duet Display, Spacedesk, Splashtop Wired XDisplay, and Deskreen. These apps can turn your Chromebook into a second monitor by transmitting the display data wirelessly or through a USB cable.
Now, let\’s see what we need to do:
  • Duet Display: This one\’s a paid app, but it\’s quite versatile. You\’ll need to install it on both your devices. Once that\’s done, just create a shared account, enable screen sharing, and connect over Wi-Fi or, ideally, a USB for better performance. You can then decide whether you want to mirror your main screen or extend it for more workspace.
  • Spacedesk: If you’re on a budget, Spacedesk is a free option that plays nice with Windows and Android-based Chromebooks. Make sure both your devices are on the same network. Install the app on each, pop in your PC\’s IP address on the Chromebook, and boom, you\’ve got a connection. You can mirror the screen or stretch it out for extra room.
  • Splashtop Wired XDisplay: Prefer the old-school wired approach? This app uses a USB cable to link your Chromebook and PC. It’s a solid option if you want less lag. Just install and set it up on both gadgets and decide if you fancy a mirrored or extended screen.
  • Deskreen: An open-source favorite, especially if you\’re hanging out in the Linux camp, though it works on Windows and macOS too. Deskreen creates a wireless connection to use your Chromebook as a second display. It even offers a cool teleprompter mode if you\’re feeling fancy.
A few things to keep in mind:
  • For those wireless setups, make sure both devices are on the same Wi-Fi for a smoother ride.
  • You can tweak display settings like resolution and orientation to fit your style.
  • Remember, Chromebooks are limited to output ports, so no direct video input.
  • Thinking about costs? Duet Display, though a paid service, might give you a snazzier connection than the free options, but those freebies still do a decent job if you\’re on a tight budget.
Using these software hacks, your Chromebook can double as a second screen, making multitasking a breeze and boosting your productivity without breaking the bank on extra monitors!
Turning Your Chromebook into a Monitor: Here’s the Scoop
So, can you just take a Chromebook and use it like a regular monitor? Well, I hate to break it to you, but out-of-the-box, it\’s not really doable. The biggest snag is that Chromebooks don\’t have the necessary video input ports (like HDMI-in). Most of these devices are all about sending signals out to other screens, not the other way around.
First off, they lack those crucial video input ports. And let\’s not forget, Chrome OS just isn\’t built to support such a feature. Unlike some older MacBooks that let you turn them into displays, Chromebooks keep their doors shut to incoming signals.
Typical reasons folks try to make this work:
  • Trying to extend their PC/Mac screen onto the Chromebook.
  • Recycling an older Chromebook as a secondary display.
  • Hooking up gaming consoles, like a Nintendo Switch, to play on the Chromebook.
Workarounds to Get You Close Enough
Even though you can’t plug it in directly, there are sneaky ways to get around this hurdle.
A. Remote Desktop or Screen Mirroring – When Cables Aren’t Your Thing
These options can stream your main device’s screen to the Chromebook over Wi-Fi:
  1. Chrome Remote Desktop: Pop this onto both devices, then enable remote access on your main gadget and connect through your Chromebook online. It\’s not where you’d want to game, but it works for casual use.
  2. Third-Party Apps: Try TeamViewer or Splashtop. It\’ll let you see and manage your main device from Chromebook. Splashtop is solid if you’re watching videos.
  3. Smartphone Mirroring: You can use features like Google Cast to show your phone’s screen on your Chromebook. Easy stuff.
B. Wireless HDMI Adapters – Cutting the Cord (Almost)
In search of low-latency options for your gaming console? Look into wireless HDMI transmitters. Here’s how you get it rolling:
  • Get your hands on a wireless HDMI kit.
  • Link up the transmitter with your device\’s HDMI port.
  • Head online via your Chromebook to the receiver’s IP (provided it supports this).
Note: Not every Chromebook will play ball with this setup, so double-check compatibility beforehand.
C. USB Capture Cards – For the Tech-Savvy Adventurer
For those who don’t mind a challenge, try USB capture cards:
  1. Grab a USB-to-HDMI capture card.
  2. Run an HDMI cord from your device to the capture card.
  3. Plug it into your Chromebook and use suitable software (possibly via Linux) to see the feed.
Bear in mind, this approach is a little more complex and may have some tricky compatibility issues.
Why Bother Trying Anyway?
  • It saves cash by dodging the purchase of a new monitor.
  • Chromebooks are light and easy to cart around.
  • Great fix when you temporarily need an extra screen.
Wrapping It Up: What’s Worth Trying?
For most everyday uses, stick with remote desktop services or wireless casting. But if you’re after a gaming setup, those HDMI adapters or capture cards are your best bet, assuming you\’re cool with a bit of tech work.
While the current batch of Chromebooks might not be built for this, appliance tech changes quickly, so keep an eye out for any shift in what upcoming models might offer.
