Can You Connect A Ps3 Controller to A Pc?
329 viewsGame Console
PlayStation 3 (PS3) controllers are known for their comfy design and solid controls. A lot of PC gamers want to hook up their PS3 controllers to their computers for a better gaming vibe, especially for emulators or games that support gamepads. There are a few ways to get this done, and each one has its own steps and requirements. Check out this guide to help you connect your PS3 controller to your PC smoothly.
Why Use a PS3 Controller on Your PC?
Before getting into the connection stuff, you might wonder why you’d use a PS3 controller on your PC. Well, here are a few reasons:
  • Ergonomic Design: The controller feels great in your hands, perfect for long gaming sessions.
  • Precision Controls: With its unique analog sticks and pressure-sensitive buttons, you get a good grip on different game genres.
  • Versatility: Besides gaming, it can also work with emulators like PCSX2 for PS3 games or even as a general remote for media centers.
What You Need
Before you start, make sure you have:
  1. A PlayStation 3 DualShock Controller: Ensure it’s working and charged.
  2. A PC (Windows or Linux): This guide is geared towards Windows, but Linux users can follow along with slight changes.
  3. USB Bluetooth Adapter (for wireless): If your PC lacks built-in Bluetooth, get an adapter.
  4. A Micro USB Cable: Needed for wired connections and initial setup.
  5. Software: Programs like SCP Toolkit or DsHidMini for drivers and configuration.
Method 1: Wired Connection
Connecting via cable is the easiest way. Here’s how to do it:
  1. Install Drivers: Download and install SCP Toolkit from a trusted source. During installation, you might need to add extra components like the Xbox 360 controller drivers.
  2. Connect to PC: Plug one end of your micro USB cable into your controller and the other into your PC.
  3. Run SCP Driver Installer: Open the SCP Toolkit, which should detect the controller. Follow the installation steps to get the drivers sorted.
  4. Test Your Controller: Head to the Control Panel, pick ‘Devices and Printers,’ and see if your PS3 controller shows up. Test it with a game to make sure everything works fine.
Method 2: Wireless Connection (Bluetooth)
If you prefer wireless, here’s what you need to do:
  1. Install SCP Toolkit: Make sure the tool is installed just like before.
  2. Connect via USB Cable: First, plug in your PS3 controller to your PC with the micro USB cable for initial pairing.
  3. Enable Bluetooth on Your PC: Turn on your Bluetooth adapter and put your PC in discoverable mode.
  4. Pair the Controller: Press the PS button on the controller (the one with the PlayStation logo). SCP Toolkit should sync it via Bluetooth.
  5. Disconnect the USB Cable: Once paired, unplug the USB cable and you’re good to go wireless.
  6. Verify Connectivity: Check under ‘Devices and Printers’ to confirm the connection. Test the controller with a game to see if all buttons and joysticks are working.
Method 3: Using DsHidMini
DsHidMini is another way to use your PS3 controller on a Windows PC. Here’s how:
  1. Download DsHidMini: Get the driver from a reliable source.
  2. Extract Files: Use a tool like 7-Zip to unzip the DsHidMini file.
  3. Install Drivers: Open the ‘dshidmini’ folder and install the ‘dshidmini’ and ‘igfilter’ files.
  4. Connect Controller via USB: Use the micro USB cable to plug your DualShock 3 into your PC.
  5. Launch DSHMC: Open the DsHidMini settings utility. Your controller should be listed on the left. Customize settings as needed.
  6. Wireless Connection (Optional): If you’ve installed the BthPS3 utility, unplug the USB, and the controller should pair via Bluetooth.
Alternative Method: Using MotioninJoy
MotioninJoy used to be popular but is now riddled with ads and security concerns. Still want to try it? Here’s how:
  1. Download MotioninJoy: Get the software from the official site.
  2. Install the Program: Run the installer and follow the steps.
  3. Connect the Controller: Use the micro USB to plug your controller into the PC.
  4. Run MotioninJoy Tool: Open the tool, go to ‘Driver Manager’ and install the drivers for the controller.
  5. Set Up Bluetooth Connection: If going wireless, use the ‘Bluetooth Pairing’ section and follow the instructions.
  6. Test the Controller: Use the ‘Test’ feature to ensure all buttons are working correctly.
Configuring Your PS3 Controller
Once your controller’s connected, you might need to tweak the controls. Here’s how:
  • In-Game Settings: Many games let you adjust controller settings in the options menu.
  • Using Additional Software: Some programs provide advanced remapping features beyond in-game options.
  • Emulator Configuration: If you’re using emulators, go into the settings to map the PS3 buttons correctly.
Troubleshooting Tips
If stuff isn’t working, try these tips:
  • Driver Issues: Reinstall the drivers or check for updates if the controller isn’t recognized.
  • Bluetooth Connectivity: Make sure your Bluetooth adapter works and that your PC is discoverable. A restart often fixes connectivity issues.
  • Software Conflicts: Using multiple tools might cause conflicts. Stick to one method.
  • Controller Battery: Ensure your controller is charged, especially for wireless use.
Wrapping Up
Hooking up a PS3 controller to your PC is a game-changer, mixing comfort and precision for a top-notch gaming experience. Whether wired or wireless, the process is pretty straightforward with the right tools and steps. SCP Toolkit and DsHidMini are the go-to options right now, offering reliability and ease of use. Enjoy your gaming with the trusty PS3 DualShock controller. Happy gaming!
Okay, so you’re trying to hook up your PS3 controller to your PC—totally doable! You just need to know a couple of tricks, that’s all. You can go the traditional wired route with a USB or get fancy with Bluetooth.
First things first—gear up with the essentials. You’re going to need the PS3 controller (duh), a trusty mini-USB cable, and maybe a Bluetooth dongle if your PC isn’t the Bluetooth fairy itself. Here’s the secret sauce for Windows users: download DsHidMini for Windows 10 or 11, or ScpToolkit for our pals on Windows 7 or 8. These software options are going to bridge the gap between your PS3 controller and your gaming PC.
Now, let’s get down to business. If you’re going wired, start by installing the right software—grab DsHidMini for newer setups or ScpToolkit for the vintage Windows versions. Then you’re ready to plug the mini-USB cable into your DualShock 3 and connect to your PC. Especially if you’re using ScpToolkit, you’ll need to run the Driver Installer—make sure Install DualShock 3 driver is checked and select your controller from the list. Hit install and bam, you’re golden!
For DsHidMini users, run DSHMC.exe as Admin, and switch to SDF mode. This step helps with emulator compatibility like PCSX2 and RPCS3. Now, make sure everything’s working by testing out your controller—should act just like an Xbox one in games that support gamepads.
Feeling wireless? No worries! Firstly, your PC might need a Bluetooth dongle. Start by connecting your DualShock 3 to the PC via USB, let it settle in, then unplug the cable. Ideally, the controller should sync up via Bluetooth automatically. If it doesn’t, maybe your Bluetooth setup needs checking out.
After all the techy stuff, fire up your games. Most of them on Steam gel nicely with the PS3 controller, though there may be some tweaks needed if you’re using emulators for those retro favorites.
So, yeah, with the right steps, your PS3 controller can be a game-changer for your PC gaming experience.
So, you want to hook up a PS3 controller to your PC? Absolutely doable, but it does involve jumping through a few hoops compared to newer consoles like the Xbox or PS4/5. Here’s the scoop on how to get it done without pulling your hair out.
Why It’s a Little Tricky
Here’s the deal: PS3 controllers use a special communication protocol, which means your PC won’t recognize them right off the bat. When Sony made the PS3, PC compatibility wasn’t exactly top of their list. That’s why you’ll need some extra tools to make it work on Windows, macOS, or Linux.
Ways to Connect a PS3 Controller to a PC
1. Using a USB Cable
  • Here’s What You’ll Need:
    • Your trusty PS3 controller (don’t mess around with knock-offs).
    • A mini-USB cable (usually comes with the controller).
    • Software like SCP Toolkit or DS3 Tool.
  • How to Do It:
    a. Install the Necessary Drivers:
    • On Windows:
      • Grab SCP Toolkit (it’s the reliable choice for this task).
      • Run the installation and make sure to choose the DualShock 3 driver.
      • Plug in your controller with the USB cable and let the magic happen.
    • On macOS/Linux:
      • Try out qtsixa (Linux) or Enjoyable (macOS) to set up your buttons.
    b. Check If It’s Connected:
    • Peek into Device Manager (Windows) or system input settings and see if the controller is showing up. If the lights are steady, you’re golden.
  • Common Bumps Along the Way:
    • Drivers might clash with other controller software.
    • No worries: just uninstall any conflicting drivers like Steam configs before you set up SCP Toolkit.
2. Going Wireless with Bluetooth
  • What You’ll Need:
    • Bluetooth 2.0+ adapter (either built-in or an external one).
    • Software like SCP Toolkit for Windows or Sixaxis Pairing Tool for cross-platform use.
  • Steps:
    a. Get Pairing Done:
    • Windows Users:
      • Install SCP Toolkit and enable Bluetooth drivers during the process.
      • Fire up SCP Monitor, right-click the controller, and hit Pair.
    • macOS/Linux Users:
      • Go old-school with terminal commands like sixpair on Linux to sort out the pairing.
    b. Fix Connection Hiccups:
    • If things get disconnected, just press the tiny reset button on the back to get it going again.
    • Make sure your Bluetooth adapter is on good terms with the PS3’s encryption stuff (some older ones might be stubborn).
3. Using Steam for a Quick Setup
  • Steps:
    a. Enable PS3 Support in Steam:
    • Pop open Steam > Settings > Controller > General Controller Settings.
    • Put a checkmark on PS3 Configuration Support.
    b. Connect via USB or Bluetooth:
    • Steam’s own drivers make third-party tools often unnecessary.
  • Know the Limitations:
    • This approach works only for Steam games. For anything else, maybe roll up the sleeves and do some extra configuring.
Why the PS3 Controller Might Play Hard to Get
  1. Driver Drama:
    • Fix: Ditch MotioninJoy for SCP Toolkit—less headache, no malware risk.
  2. Bluetooth Beef:
    • Fix: Get a Broadcom-based adapter like the Asus BT-400.
  3. Battery Blues:
    • Fix: Do a full charge with a wall adapter for about half an hour before pairing.
Other Avenues
  • DS4Windows: Go for a PS4 controller instead; it plays nice with PCs.
  • XInput Wrappers: Use tools like x360ce to get the PS3 controller acting like an Xbox one.
Some Handy Tips
  • Steer clear of loading up different driver tools at once to avoid a hassle.
  • Give your controller a whirl on Gamepad Tester online to make sure everything’s mapped right.
  • If you’re on macOS, check out apps like Joystick Mapper for a custom touch.
If you follow these tips, you’ll likely get your PS3 controller connected without too much fuss. Although it’s not the easiest choice for PC gaming, it’s still a solid option for budget or retro setups.
Alright, you might be wondering how to get your PS3 controller hooked up to your PC. Here’s the scoop: it’s totally doable, whether you’re going down the wired or Bluetooth route.
Let’s kick things off with the wired method:
  • First up, grab the SCP Toolkit from GitHub. Just hit up the site, download it, and follow the steps to get it installed. It’s pretty straightforward.
  • Connect your PS3 controller with a USB cable. It’s as simple as plugging it in.
  • Now, fire up the SCP Toolkit Driver Installer. Make sure you check that box for ‘Install DualShock 3 driver’, pick your controller from the menu, and hit ‘Install’. Give it a sec to do its thing.
Moving on, here’s how to go wireless with Bluetooth:
  • Double-check your PC has Bluetooth and it’s turned on. No Bluetooth? No wireless play, unfortunately.
  • If you haven’t got the SCP Toolkit installed yet, follow the earlier steps to sort that out.
  • Time to pair up! Open SCP Toolkit and run the Pairing Utility. Unplug the USB cable to let your controller connect through Bluetooth. Just follow whatever steps pop up to finish pairing.
And there you have it; with these steps, your PS3 controller should be ready to rumble on your PC. Remember, you might need to tweak a few updates or patches if you’re rocking a newer Windows version. Happy gaming!
