Why is my Android phone able to make calls but not receive them?
280 viewsPhone
Alright, so you\’re able to make calls on your Android, but for some odd reason, the incoming ones aren\’t coming through? Let\’s dive into what could be going wrong here and how to fix it, like, yesterday.
Having a glitch like this often means your phone\’s pretty good at sending calls out but trips up when they\’re coming in. It might be network settings acting up, some sneaky software bugs, or even just a finicky SIM card. Let’s see how to put things right again.
First up, check your network signal. Sounds obvious, right? But sometimes moving around can throw things off, especially if you\’re near a border or cell tower. If you\’re not careful, you might end up in a spot with zero bars.
Next, have a look at Airplane Mode. I know, I know, it\’s meant for the skies, but if it\’s on, nothing\’s getting through. Same with Do Not Disturb—check that you didn’t flick it on by accident, or else your calls might just be heading straight to voicemail on the down-low.
Then, see if call forwarding is messing up your flow, or if you’ve blocked someone by mistake. Go through those settings like a detective on a case. Giving your SIM card a little flick in and out might bring back the incoming chatter if something got stuck.
Now, here\’s a curveball—Wi-Fi Calling. If it’s on, it might have a beef with your regular call settings. Switch it off for a sec and see if that helps.
A quick reboot can sometimes work wonders; it’s like turning your phone off and back on again shakes out the cobwebs. Clearing the Phone app\’s cache once in a blue moon can also do the trick.
Don’t forget about those software updates. It’s easy to ignore the update notifications forever, but a missed update could be why you\’re dodging calls unintentionally.
For those using VoLTE, take a peek and ensure it’s on. It\’s like a superpower for your phone, letting calls move through LTE networks, so you don’t want it sidelined.
And hey, if you’re still in the thick of these call woes, reaching out to your carrier might be the ace up your sleeve. They might have some insights or need to send you a fresh SIM card.
Wrapping this all up, breaking down the problem step by step and tweaking these settings is more often than not all it takes to get calls coming through again. If after all this you\’re still hitting a wall, your carrier\’s support is one call (or maybe text) away.
So, your Android phone is acting up and it can make calls but can’t receive them? That’s frustrating, but don’t worry, there are a few things you can try to get it sorted out.
  1. Signal Check: First off, take a look at your signal. If you’re in a dead zone, that could well be the culprit. Moving around or toggling on and off Airplane Mode might just do the trick.
  2. Quick Restart: Ever tried turning it off and back on again? A restart can work wonders more often than you’d think.
  3. Call Blocking Peek: Dive into your settings to ensure no contacts are mistakenly blocked. Look under Settings > Apps > Phone > Call Blocking.
  4. Do Not Disturb (DND) Check: Make sure you’re not on DND mode—check Settings > Sound > Do Not Disturb. You wouldn’t want those calls to be sent to voicemail without you knowing!
  5. SIM Card Scrutiny: Sometimes, it’s the SIM card. Carefully pop it out, check for damage or dirt, and then slide it back in—it could be a simple connection issue.
  6. Carrier Settings Update: Are your carrier settings behind the times? Head over to Settings > About Phone > Carrier Settings for an update, or give your provider a ring if you’re unsure.
  7. Call the Experts (Carrier Support): If you’re still in a pickle, it could be a carrier-side issue. Don’t hesitate to reach out to them for some help.
  8. Factory Reset (Last Resort): Alright, if nothing seems to work and you’re down to the wire, a factory reset might be your last shot. Make sure to back up your stuff first, though!
These steps should help you tackle the issue with your calls. If it’s still being a nuisance, it might be a hardware problem, and you might need to get a tech-savvy friend or professional involved.
Figuring Out Why Your Android Phone Can Make Calls but Can\’t Get Them
Alright, so your Android is letting you call folks but not hear from them. What\’s up with that? There can be a bunch of reasons, from wacky settings to weird network stuff. Let\’s get into it and sort this out:
1. Trash Network Signal & Coverage
If you\’re not getting calls, your signal might be having a meltdown. Even if you can send calls out, your incoming calls might get lost in the chaos.
  • Peek at Signal Strength:
    • Swipe your status bar for a look at the signal bars. Anything less than 3 bars? You might wanna hover near a window or head outside for better reception.
    • Try apps like OpenSignal or your carrier’s coverage map to check how your network’s doing.
  • Switch Network Modes:
    • Go into Settings > Mobile Networks > Preferred Network Type.
    • Play around with 4G/5G and 3G/2G modes, because sometimes older networks have their act together more.
  • Airplane Mode Trick:
    • Flip on Airplane Mode for a bit (like 30 seconds), then turn it off to give your network connections a fresh start.
2. It\’s All About Those Device Settings
Misguided settings could be messing with your incoming calls, putting up barricades without you knowing.
  • Kill the Do Not Disturb (DND) Mode:
    • Check out Settings > Sound > Do Not Disturb and make sure calls can get through even when DND is on.
  • Peek at Call Forwarding/Restrictions:
    • Dial *#21# to check call forwarding. Reset it through Settings > Calls > Call Forwarding.
    • Look over blocked numbers in Phone app > Settings > Blocked Numbers.
  • Reset Network Settings:
    • Jump to Settings > System > Reset Options > Reset Wi-Fi, Mobile & Bluetooth. This should clear out any annoying carrier glitches without messing with your personal data.
3. SIM Card Struggles
Sometimes the real culprit is a rogue SIM card—badly inserted or just plain old.
  • Reinsert the SIM Card:
    • Turn the phone off, yank out the SIM tray, clean the contacts, and put the card back in right.
  • Test with Another SIM Card:
    • Borrow a SIM from the same carrier to see if it’s just your card that’s causing trouble. If so, get your carrier to send a new one.
4. Software & OS Shenanigans
Every now and then, a little software glitch or an outdated system can mess things up.
  • Update Android OS:
    • Spin over to Settings > System > Software Update and check for updates sitting there, waiting to be installed.
  • Clear Phone App Cache:
    • Go to Settings > Apps > Phone > Storage > Clear Cache. Give Carrier Services a good clean-up too.
  • Safe Mode Adventures:
    • Boot the sucker into Safe Mode (hold down the power button, then tap and hold \”Power Off\”). If calls kick in here, a troublesome app is your villain. Boot out any recent ones you installed, like blocky apps or hawkish antivirus programs.
5. Hardware or Antenna Crashes
Physical stuff like antenna damage or getting caught in the rain can really hassle signal reception.
  • Sniff for Damage:
    • Look at the Liquid Damage Indicator (LDI) inside the SIM tray. If it\’s rocking a pink/purple tint, then we might have some water trouble.
    • Test out reception in a few spots. If signals are consistently in the toilet, the antenna could be suspect.
  • Hit Up a Pro Repair:
    • If you suspect a hardware fail, reach out to authorized service centers for a deep dive diagnosis and repair.
6. Carrier Account or Service Freakouts
Your account might be in lock down mode, or there could be something funky on the carrier’s end.
  • Get in Touch with Carrier Support:
    • Do a status check on your account (maybe those bills are neglected, leading to service suspension) and ask them to rejigger your network settings.
    • Inquire about any outages or maintenance happening in your area.
7. VoIP/App Hassles
Apps like Skype might be hijacking your call permissions and jamming things up.
  • Purge App Permissions:
    • Explore Settings > Apps > [VoIP App] > Permissions and switch off Phone or Call Log access.
  • Ditch Suspicious Apps:
    • Get rid of third-party dialer apps, call recorders, or mods that mess with your phone’s call framework.
8. Factory Reset (When All Else Fails)
If none of the above vibes, back up your stuff and go for a Factory Reset (Settings > System > Reset Options) to smack any stubborn software corruption into oblivion.
Extra Tidbits
  • Permission Checks: Keep your eyes peeled on permissions like READ_PHONE_STATE and ANSWER_PHONE_CALLS for your Phone app.
  • Regular Maintenance: Make a habit of clearing cache partitions and steer clear of unofficial OS tweaks to avoid call disruptions.
With these tricks up your sleeve, most Android call reception snafus shouldn\’t stand a chance. But if you\’re still scratching your head, don’t hesitate to hit up your device manufacturer or carrier for backup.
